Need help with setting up Bridge Mode on Genexis Platinum-4410
  • Thread starter Thread starter wazarikun
  • Replies Replies 19
  • Views Views 22,905
Please Suggest Best wifi Router for MTNL Delhi Genexis - Wifi ac or Wifi ax and how to configure. I m getting Speed of 30 mbps with provided router on Wifi. But when i check with cable, its giving 300 mbps.
I have tried both TP-Link AC ROUTER AC 1200 (MODEL C6) , And TP-Link AX ROUTER AX 10 (1500) with MTNL ONT genexis (Delhi). I have tried both LAN Post and Wifi ac and Wifi 6 (on Samsung S10 Plus).
I am getting 80 to 90 mbps on both LAN and wifi. My Plan is of 500 mbps. Do i have to change any values in Bridge Mode in MTNL ONT ?? I got 300 mbps on MTNL modem via LAN (in ROUTE MODE).
I have been using the C6 by connecting via lan cable till now leading do double NAT. I want to switch to using it via bridge mode. I don't really know how to proceed, kindly guide me with the necessary steps.
Thank you.
I managed to get it working, but now I am facing network issues, (pages not loading unless I refresh it multiple times) I think I am facing a double NAT, Could you check this thread I made with the settings and see if there's any issue?
I'm facing the exact same problem as OP. But while changing the mode to bridge, it shows a popup saying that current broadband calls must be ended inorder to save the changes. But there are no VoIP phones connected to the modem.
