New Connection, Speed Issue
  • Thread starter Thread starter amitwiz1
  • Replies Replies 19
  • Views Views 4,423
amitwiz1
Regular
BSNL Home 500C
Hi,
I just received my BSNL modem, all connections are perfect. My Plan is Home 500C. Phone line and Net work. Router in bridge mode.
My Modem is Type 4, UT Starcom WA3002G4 w Wifi. The speed is low, around 600-1100kbps. I dont mind the speeds, but it would be nice if I could get around 1.7mbps :D
Here are my stats:
Downstream Upstream
SNR Margin (dB): 25.3 19.5
Attenuation (dB): 23.0 9.8
Output Power (dBm): 12.2 19.7
Attainable Rate (Kbps): 20490 1243
Rate (Kbps): 7996 764
MSGc (number of bytes in overhead channel message): 59 15
http://img514.imageshack.us/my.php?image=snrtg8.jpg
ipconfig/all:
Windows IP Configuration
Host Name . . . . . . . . . . . . : Amit-PC
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
PPP adapter BSNL_BB:
Description . . . . . . . . . . . : BSNL_BB
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
IPv4 Address. . . . . . . . . . . : 117.193.5.185(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 208.67.222.222
208.67.220.220
NetBIOS over Tcpip. . . . . . . . : Disabled
Description . . . . . . . . . . . : Intel(R) 82566DC Gigabit Network Connecti
on
Physical Address. . . . . . . . . : 00-19-D1-9E-59-A5
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::f915:537a:96b2:497f%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
Lease Obtained. . . . . . . . . . : Monday, January 05, 2009 1:49:44 PM
Lease Expires . . . . . . . . . . : Tuesday, January 06, 2009 1:52:31 PM
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 201333201
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : isatap.{8FC82B3A-7D7C-4D7F-9A87-F69B7EA1D
FCC}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.2%19(Preferred)
Thanks,
Amit
your numbers seem to be okay. how did you measure your download speed? try multiple torrents/downloading simtaneously to try to max out the speed. in any case the speed is only 256 kbps... "upto" 2 mbps... you can't have your cake and eat it too! :Dtry disabling IPV6 in your internet options...i see you are using opendns already
Simultaneous torrents gives me a max of 99kbps.
Speed in various test sites doesnt cross 1.1mbps
I Know. Well, no harm in being greedy for speed. :p
DRTCP: How do I use it, & what are all these settings?
or
TCP/IP optimiser from speedguide.net.
Test at one site after any tweaks you make.
My Airtel 2 Mbps connection. 800 Kbps to 1790 Kbps.
1.
https://www.speedtest.net/result/384400597.png
Hong kong 800 359 163ms
2
https://www.speedtest.net/result/384401561.png
Melbourne 1108 294 kb/sec 318 ms
3
https://www.speedtest.net/result/384402437.png
LIsbon 1434 kb/sec 143 kb/sec ping 367 ms
4.
https://www.speedtest.net/result/384403337.png
Mumbai 1790 kb.sec 401 kb/sec ping 152ms
Oops! I dont know what happened, but all of a sudden I cant connect to BSNL (bridge mode). It doesn't proceed from the Verifying Username / Password... Dialog. (I am curently on a different connection)
Help.
on
Autoconfiguration IPv4 Address. . : 169.254.73.127(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Update :
I can now connect but I cant access 192.168.1.1 telnet/firfox.
Site says: "Level 15 Access"
Whatever it was, it fixed itself after two reboots
After setting options in TCPOptimiser to Optimal setting, speeds have gone to 2000kbps but ping has risen to 980 ms ... (Tested thrice on 2 websites)
Thanks essbebe, any suggestions for the ping ?
Please explain how. Currently I assigned IP 192.168.1.21 to My LAN (this works, but I am wait for almost 10 minutes after startup to connect) . If I leave IP blank for LAN the connection doesn't work. If I set IP as 192.168.1.1 it says conflict present.My dialer has no IP (auto). Open DNS nameservers set here
@amitwiz1
1.Link-local IPv6 Address . . . . . : fe80::f915:537a:96b2:497f%8(Preferred)
disable in TCP/Ip properties
2NetBIOS over Tcpip. . . . . . . . : Enabled
select default ( IN tcp/ip properties DNS Advanced WINS)
3.Autoconfiguration IPv4 Address. . : 169.254.73.127(Preferred) local LAN
Usually appears as default.
169.254.73.127 - - - 0
0 - -
Net Speed ISP Domain
- PRIVATE IP ADDRESS LAN
Not correct . should be 192.168.1.X
Select Obtain Ip address automatically.
in TCP/IP properties.
in modem enable DHCP server. range 192.168.1.3 to say 192.168.1.30
Para two
A):https://www.speedtest.net/result/384467034.png
please give details of MTU MSS TTL etc
or the full page. of settings made. in TCP/IP optimzer.
B)About Ping: will update later.
Usually DNS change may work sometimes. ( you are using Opendns OK)
cmd tracert www.xxxxx.com and see the path.
If I set to obtain IP Automatically... The Network is "Identifying" and the ip is assigned later as 169.254.73.127How can I use DHCP while in bridge mode ?
