new plan old speed
  • Thread starter Thread starter target_13
  • Replies Replies 5
  • Views Views 1,220
target_13
bsnl
hi guys , I changed my plan to home 1000 from ul 900 from 1st april. I live 1.5 kms from the exchange and my speed does not go above 60kbps yet !! my modem is huwaei mt882. Do i need make any changes to the modem settings? if yes kindly advice how.thanks.
are you sure your plan has changed?login into bsnl portal with 14characters portal ID(provided by bsnl usually local exchange) & click on "my orders"tab.see what plan is shown there.it should be home 1000,order status--provisioned,order type--plan changed.
as mrbgupta said,open your modem home page(192.168.1.1 generally)& look for something like status.there look for values downstream rate.upstream rate,SNR,Line attn & post them here.on a side note when you login into portal to check your usage click on my orders tab.you should see order status as---provisioned.if it is something else chances are your plan is still not changed yet even if it shows plan changed.
