New Promotional BSNL Broadband Plan BBG SPEED COMBO ULD 1091 CS70 Plan - 8 Mbps till 60 Gb
Hi, After submitting broad band req change I got a message like :
Dear Customer, Your Request for Modify(Broadband Modify) of phone (080-xxxxxxxx) with reference number 11417xxxxxxx is Provisioned. Please contact 1500 for any queries. Thanks for your continued patronage to BSNL.
Can I consider this message as successful service??
When I checked in selfcare under Broadband services, it is showing blank..
You can run a broadband speed test to check whether you have been migrated to higher speeds or check your DSL stats and see whether the speed for the new plan is reflected there.
Yep bro... Tested... Its reaching till 6.7mbps...
I thing it got successfully changed. [emoji41]
