eriek_halenx
I got banned!
@ahamed , if i understood correctly, that your lan speed is full 50, and 2.4 ghz WiFi speed is less...Usually, the WiFi device given is of a lesser quality and may have only limited capability.
Wifi speed depends on a number of factors. Range of router, interference, channel number, capability / distance of device using the WiFi etc etc. You could also try install an android app like wifi analyser to check if a) wifi signal strength is good. And b) If there is channel interference.
Perhaps these posts are helpful if you want to do a router upgrade.
