PC Build for around Rs. 35000
  • Replies Replies 35
  • Views Views 4,452
So, I am in process of building a PC for a nephew. Budget is around 35K. For office use mainly so gaming was not a requirement. I am posting the specifications I went for.
I am not necessarily looking for feedback because I have ordered all components, so it is a bit late to make any changes.
But do feel free to suggest alternative builds or recommendations that can come handy for someone else who might be looking for a similar build. Plus if this is something that interests you, feel free to start new threads catering to different budget segments! Would have saved me a lot of time bothering friends into researching.
Not that many people use desktops these days.
Processor: AMD RYZEN 5 3500
Motherboard: ASUS PRIME B450M-A
GFX: ASUS GeForce GT 710 1GB GDDR5 (This was needed because processor lacks an integrated GPU. Also ordered the 2GB variant instead of 1GB)
SSD: Kingston A2000 250GB M.2 2280 NVMe PCIe SSD SA2000M8/250G
RAM: 2 x CORSAIR 8GB DDR4 2400 MHZ
PSU: Antec VP550P Plus 550 Watt
I haven't yet decided on a cabinet yet because that I wanted to get locally. Would see what is easily available locally tomorrow.
From what I heard from @Sushubh he found Wraith cooler that comes with Ryzen 3xxx slightly more noisier than his existing Intel system i5-4xxx. I didn't feel much of a difference as far as noise is concerned.
You won't be able to get Ryzen 5 3600 + GPU for 15k since 3600 itself retails for ~16.5k.
The system in discussion here with very basic GPU costed around 30k I think.
Looking at this thread I am wondering why did I get an A400 and not M.2, just a week ago :confused:
No mean i don't wanna spend 14k to 15k on cpu.and not more than 12k on GPU probably
I need to use some softwares released years ago, will there be any issues with amd ? and @Nishant can you test adobe products (photoshop, premiere pro) on this system, I have to do some minor video editing so any idea if this setup can handle that?.
I assume Photoshop and Premier Pro would be dependent on GPU too. And currently the GPU installed in my new system is kinda old (GTX 650 1GB).
typically it should not be an issue, but if the old software is using some intel-specific instructions it can crash on AMD CPU. but older software is not an issue normally, its the newer software that can fail.
  • Like
Reactions: Smh
