D
Deleted member 83050
Recently i have been doing a bit of digging on the internet about pfSense Firewall and planning to set it up in my home network. I have figured out the basics on how to get it working on a machine. Just had a few questions related to it and looking forward for some advice.
1. Since i am just starting out, i don't want to spend a lot of money initally. Was thinking of getting a old small form factor PC like Lenovo Mini PC or Dell Optiplex and flash pfSense on this. As per my research i have to buy a Dual/Quad Port 1GbE or 10GbE NIC PCIe card because i need minimum of 2 ports. What are the options available in the market? I am a little hesitant to import these products from China via AliExpress. Can i get it somewhere in India Itself, like LT Store?
2. Another option is to get an industrial PC something like this but this seems a bit expensive. Are there any cheaper industrial PCs available?
3. Another option which comes to my mind is to build a custom PC under a certain budget like 15-20k(with NIC) and flash pfSense on it. A noob question - Does AMD work fine with pfSense or i need to buy intel CPU only?
I am also a little worried about power consumption. What are the ways to minimize it?
My requirements:
1. I am currently on the 200 Mbps Plan but i might move to a higher plan maybe 500 Mbps with some other ISP. What things i need to keep in mind in order to remain future proof? Is it safe to get a 2.5 GbE ONU?
2. I may also want to setup two ISPs(dual wan) in failover or load balancing. What kind of NIC do i need then?
My requirements:
