hi...i downloaded one serial from dctorrent .. the avg downloaded sped is just 40KBps... i think i have adjust some setting in u torent.. what should be the
global upload rate for my connection... currently i set 186kBps...can i switch to azures or some other stuffs?????????????
get back to your default settings in Utorrent...
(close u torrent before doing this)
go to
start > run > %appdata%\utorrent >
Remove settings.dat
may be this should help you.. just google for more...
go to
Remove settings.dat
