I recently upgraded to the Airtel Black 3999 plan to test the 1Gbps speed. After the upgrade, a router change ticket was created. However, I later found out from the LCO and the engineer that the maximum available speed in my area is only 300Mbps. They also informed me that they don't even have the required router for the upgrade, and I'm using a different setup (XZ000-G7 and AX10 router) than the provided router.
Now I'm stuck with the 3999 plan in the app, but my DTH and broadband are showing as the 1098 plan, which is for 200Mbps. The maximum speed I'm getting is also 200Mbps. When I contacted customer care and the senior desk, they kept repeating that they had escalated the issue to the backend team and that a plan downgrade was not possible due to a pending order on my account. I can't make any changes through the app either.
I even raised the issue on PGPortal because the nodal officer wasn't responding, which has been going on since the 8th of July (Since last 14 days)
Has anyone else faced a similar issue? Do you know how they are going to bill me? Will it be based on the 3999 plan or the 1098 plan? Customer care and the senior desk seemed unsure and said the bill would be based on the 3999 plan, but they mentioned they could provide a waiver. However, they couldn't tell me the exact amount, like if the 3999 would be entirely waived off or not.
