i m having dna-a211-i modem...green light at inet is not blinking sometimes..so my net is disconnecting frequently...i donno whehter it is network problem or my router probleem..how to rectify this problem...:icry:
Presume all PHones ARE CONNECTED aFTER ADSL splitter.
Check in STATISTICS ADSL DATA.
report mod mode selected ( adsl2+ gdmt etc ) GDMT preferred.
SNR d/l U/l Attn d/L U/L line rate and rate.
Disable Box Client TR-069 ( see under management/maintenance)
Check "Sticky" post for WA 3002-G4 here.
Software upgrade for DNA A211-I , if you are confident.
