Printer for home usage
  • Thread starter Thread starter imdarkray
  • Replies Replies 72
  • Views Views 6,422
imdarkray
n00b
Patna, Bihar
Airtel Xstream, Jio Fiber, Railwire, Siti, Airtel 4G, Jio 4G, VI
Hi,
I am looking to buy a Printer for home-usage. Any suggestion considering the following points is appreciated.
The expected usage is very less. might be one or two times a month (10 pages). Sometimes, it won't even be used for months. So I am expecting something in which the ink doesn't dry. After some of my research I am looking for these features:
1. Document scanning
2. Auto duplex printing
3. Auto Paper Feeder
4. Less frequent ink change (should not dry in case of long term non-usage)
If there is any other considerable feature that I am missing, please let me know.
Thank you.
I am not very sure. Something which scans/prints both sides together?
Yes. Color printing is must. Did you mean just black and white printers? Do they exist in this timeline :p ?
Yes. Because laser are a good option if you are worried about ink drying.
I would recommend this. DCP-T820DW
But you would have to regularly take out a print to keep the head clean. That's what I am doing with mine without adf. I keep a sample page on my phone and take a print of it at high quality once every 10 days or so.
This is the major issue for me.
Sometimes there would be no one available at my home for months who can take printouts. And I am worried, that would destroy the printer.
I don't think auto scanning of both sides of the paper is a feature that is available on consumer printers though.
Printing on both sides at once is also good enough. Just looking for the latest possible features.
Any idea about ink tank printers?
the above model i linked is a ink tank printer! non ink tank printers with adf are cheaper. HP had a model for around 7k but ink is expensive and cartridges dry up due to non usage. in ink tank printers, head dries up but since ink is cheap, it is just simpler to take a dummy print now and then.
if you can ignore color, you can get a laser with duplex and adf that would not require regular usage as lasers do not suffer the drying problem. the more expensive option is to get a color laser with duplex and laser. brother's model starts at around 35K for this functionality.
i just re-read your post. as long as someone is at your home... you can just tell them to take a photocopy of a colored document. no one needs to learn printing. just turn it on and press the colored photocopy button. or you can configure remote printing and get someone to turn the printer on for you to take a print from your phone or something...
My HP 1020 laser printer has finally given up its ghost not sure it's repairable. Worked flawlessly for maybe 15 years. Looking for an equivalent laser printer which is just as simple & robust. Like @imdarkray mentioned my printer job are also few & far apart scanner is not required. Any suggestions about what I should opt for? The same printer has been taken off the HP site nor is it visible on ecommerce sites.
