Hi guys,
I was using BSNL broadband for the last 5 months and had absolutely no problem. But from the last 4-5 days I am getting the following problem : whenever I try to go for a "connect" - I am getting a stuck screen with "Connecting through WAN miniport PPPoE.." after soem 30 seconds I am gettign the following error :
Error 678: The remote computer doesnot respond".
So I am not being able to connect to broadband for the last few days. I have tried to ping the ip 192.168.1.1 but it is showing the "destination host unreachable". The same problem is with another PC I have in home.
Both the LAN card are working perfectly as I can make a peer to peer between them. The 3 lamps in the
ADSL modem are steady (except the one which indicates the transfer of data).
Could anyone of you please help me out ? I badly need the broadband connection for office peropse during out of office hours.
Thanks in advance !
Hi dudes ,
fist u shouild know that this is my 1st quot
i m very familiar with ur prob. because this is the same what happened with mebefore last 10 days.
BEFORE CONTINUING I MUST TELL U THAT I M SHARING MY OWN EXPIRINCE AND IM NOT EXPERT IN THIS
CAUSE OF THIS -----
ACTUALLY A VERY SMARTAND LOYAL DUDE FROM BSNL told me this problem is common in rainy season .
MY SOLUTION-----
THAT DUDE TOLD ME TO ASK THE TELEPHONE EXCHANGE
:yahoo: TO CHANGE THE VERTICAL:thumbsup: OF THE
BOX WHICH IS LOCATED OUTSIDE OUR HOUSE AT THE POLE(WHERE ALL COLONY TELEPHONES WIRES ARE CONNECTED)
AND FINISHED IT WORKED WITH ME DUDES.
SO DO IT RIGHT NOW (IF U WANT)
ANY DIFFICULTY U HAVE, THEN I MALWAYS RADY
REPLY IS MUST
2ND IS CHECK WHETGER MODEM IS IN PPOEE OR BRIDGING MODE
IT SHOULD BE BRIDGE
Hi dudes ,
CAUSE OF THIS -----
MY SOLUTION-----
TO CHANGE THE VERTICAL OF THE
REPLY IS MUST
