Ethernet adapter Local Area Connection 3:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Broadcom 570x Gigabit Integrated Con
troller ENABLE THIS
Physical Address. . . . . . . . . : 00-11-43-47-83-C6
Ethernet adapter Local Area Connection 2ISABLE OR CHANGE SETTINGS
Description . . . . . . . . . . . : Cisco Systems VPN Adapter
Physical Address. . . . . . . . . : 00-05-9A-3C-78-00
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration IP Address. . . : 169.254.18.31 incorrect IP address
Subnet Mask . . . . . . . . . . . : 255.255.0.0255.255.255.0
Default Gateway . . . . . . . . . : NOT SEEN-
DNS Servers . . . . . . . . . . . : 208.67.220.200
............................................ADD a BSNL DNS NUMBER
para 2:
in laptop
START NETWORK LAN
Disable connection 2 or make changes ( same as for connection 3 )
Enable Connection 3. Properties
TCP/IP
Properties
Select
IP address 192.168.10
subnet mask 255.255.255.0
Default GATEWAY 192.168.1.1
dns
208.67.220.220
208. 67.222.222
Check on top of page TCP/IP
ethernet card Configure enabled or not
Save APPLY.
Reconnect laptop/ computer
Does it connect now with laptop ?
troller ENABLE THIS
para 2:
in laptop
START NETWORK LAN
TCP/IP
Properties
Select
dns
208.67.220.220
208. 67.222.222
Save APPLY.
