arian_walls
hi guys, i am facing a hell lot of a problem in Tata Sky plus. please reply and tell me if u guys are also facing these same problems1)cannot rewind live tv...always have to restart the stb every alternate day for the rewind function to work2)if rewind works in live tv then cant play rewinded stuffs....also have to restart stb for this to work as well3)few recordings dont work.....some of the recorded contents work only for 15-20 mins,then the screen goes blue,though it says that it has recorded the complete event4)recording starts automatically....without any reason,the recording begins automatically and cant even stop the recoding unless the program being recorded is completei want to know if u guys are also facing these problems or any of these problems.incase if you are also facing these problems,then i can consider it to be a common fault and can ignore itif not,then will have to place an order for a new stbPlz reply guys,i need your help
