Problems with ubuntu
  • Thread starter Thread starter ShadowfaX
  • Replies Replies 9
  • Views Views 1,881
ShadowfaX
dataone
i tried to connect my ubuntu OS to dataone by all means available but to no use...my "Huawei" modem is configured to connect to the net by itself...i tried do it manually as well as using pppoeconf.....pppoe conf gives some modem error....of cannot find pppoe concentrator(i can give screenshot if reqd....).....btw even when i m on windows(dual boot)...my mozilla browser does not work....do we have to do something with the mozila settings....i can access http://192.168.1.1 using mozilla in both windows and ubuntu.....help!!!
have you successfully used windows or any other OS before with your Huawei modem?
if you can access 192.168.1.1 then try to enable DHCP then see if it works... if DHCP is off, you can set manually the IP address in Ubuntu to something like 192.168.1.2 and subnet mask to 255.255.255.0 and also make sure your gateway is set to 192.168.1.1
if you can, post the output of "ifconfig -a" here...
note that you left-click or right-click the little network icon next to the volume icon at the top-right of yoru screen and select "manual configuration" to enter your settigns...
i forgot to mention your DNS should also be set, try first 192.168.1.1 and also the opendns servers
208.67.222.222
208.67.220.220
i tried to connect my ubuntu OS to dataone by all means available but to no use...my \"Huawei\" modem is configured to connect to the net by itself...i tried do it manually as well as using pppoeconf.....pppoe conf gives some modem error....of cannot find pppoe concentrator(i can give screenshot if reqd....).....btw even when i m on windows(dual boot)...my mozilla browser does not work....do we have to do something with the mozila settings....i can access http://192.168.1.1 using mozilla in both windows and ubuntu.....help!!!
If you are able to use it in Windows or the router is already has been configured, then technically there should not be any problem with Ubuntu.
Some check points which may help you ...
1. Set ur ethernet ip to: 192.168.1.2/255.255.255.0
2. Default gateway: 192.168.1.1
With this you should be able to access ur router from browser.
Then on Ubuntu, you will find a Networking icon on system tray, Select "Manual Configuration". Then set ur DSL connection as ...
1. user name + password
2. choose the ethernet (may be eth0)
3. set ur DNS entries
Then again click on that icon select Dialup connection -> Connect (not remembered exact menu names)
Then check whether it connects or not.
YDay I ve installed LinuxMint ( a multimedia support version of Ubuntu with codecs) and have downloaded 4 movies !
just a little more clear steps on what is mentioned above.. go to system->admin->network and choose wired connection and click on properties.. then choose Static Ip Address and enter ip as 192.168.1.10 and gateway as 192.168.1.1 ..also in the terminal type ping 192.168.1.1 to see if you can communicate with the router
thanx all for replying....1) yes, i can connect to the net using windows with the same router(doin right now) 2)ping 192.168.1.1 gives perfectr reply....my mozilla browser on ubuntu can access the modem settings and edit them... @upradhan: the dial up sttings ask for a phine num wdout which it doesnt accept....ill try again though....ip,subnet are set as u have mentioed.....i hav set the DNS i use for windows.... @vishalrao, ill do it asap...hav to reboot :cry:
i am a windows user & have used knoppix live cd to run linux to connect bsnl net just for testing & as far as i know phone no. option should not come when you are configuring a ADSL/DSL connection.
right.. it shouldnt come.. i think you are trying to configure a dial up connection.. if your modem is in ppoe mode then just ensure that your pc is getting an ip ( by doing an ifconfig in the terminal) if its in bridged mode then you gotta type sudo pppoeconf in the terminal and follow instruction
guys....thanx n sorry....it turns out everythin was fine....but its so damn slow....(google takes abt a minute or more)...it seems i din wait long enuf... ;) sorry 1ce again...but its too slow on ubuntu as compared to windows(not workable)...any way arnd that???
