I've been struggling to check who do i connect to internet using the 3G prepaid sim from BSNL.
I've tested it on my Nokia N70m, which was able to do Video Call.
I've a Vodafone modem, which shows Blue linking Light showing 3G signals are available,
USB Modem is unlocked, I am also using one free unbranded Huawei dialer software which comes for this modem to use without operator name, you can customize it to use with any operator across the globe.
I used APN as :gprsnorth3g.bsnlmobile.in
dial number : *99#
user/pass: blank
Network: GSM preferred
Band: All Band
even if i select Band as GSM900/GSM1800/WCDMA2100
and send network registration i get Success msg.
but when i dial i get
" Error 619: A connection to the remote computer could not be established, "
can someone help me on how to configure this SIM to use 3G for internet.
dial number : *99#
user/pass: blank
Band: All Band
