Re: Home Combo 900
  • Thread starter Thread starter riders4siam
  • Replies Replies 18
  • Views Views 3,166
@rider4siam
i think you didn't get my point, my actual download speed was 260 kbps average from the date of connection till 6 months ...
(downloaded upto 5 gbs per day
You have used this speed within two days in a month and your speed will go down to 256Kbps for d/l 32 KB/sec.
If everything was alright for 3 or 4 months , and suddenly something has gone bad,
you have to take action. And without technical feedback./ confirmation,
no assistance /remedy can be given.
Do you expect the speed to jump to normal suddenly ?
There is a Fair Usage Policy which limits this 4 Mbps speed , and you could not have got the
speed you claim.
Check your speed at the web site given and give feedback.
( Download:
700mb movies took 2 and a half days. 700MB in 60 hours say 12 MB/hour
download 200KB/minute apprx 32 KB/ sec means speed of 256Kbps/sec
careful with Kb kb kB Mb MB etc )
My Broadband Speed - Broadband Speed Tester Home 750 speed 512 Kbps U/L H24 No FUP increased to 1024Mbps now Chennai circle.
http://www.mybroadbandspeed.co.uk
FUP - fair usage policy.Anyways can you do a couple more speed tests. Also try speedtest.net for testing speeds.Also get us your router's statistics page. Type 192.168.1.1 in your browser and show us the image of the statistics page.Just to clear up any issues on your side.If everything is perfect on your side then you are free to lodge a complaint at bsnl.But first check your end.
@riders4siam
Your Tariff plan seems to be a 256 Kbps plan !!! If this was the speed from 1st DEC till now.
Complain to to your Exchange and ask them to change port
or switch to Home 750 512 Kbps plan ( check conditions for telephone rent/free calls )
Fair Usage Policy:
ISPs allow higher speed d/l for some plans for certain limit say 4 GB 5 GB 20 GB etc. in a month.
Beyond that the speed is reduced to say 256Kbps or 512 Kbps.
( Example at 4 Mbps speed 512KB/sec 30MB/min 1.8GB/hour ( approx max possible )
if you may exhaust the FUP limit, if you download for say 2 or 3 hours continuously some movie file etc )
You can use FireFox browser with some add ons to block ADVTS/ flash content/photos etc of
usually visited web sites and save 30 to 40% of your down load quota.
For Instance I rarely see any advts in this forum! Only when I switch to IE see them !
Looks like you were getting good speeds coz of BSNL's negligence earlier. Now that they have fixed it, you are getting the speeds which you should have got in the first place.
Your present plan UL 900 combo(no combo) provides you with a speed of 4mbps (thats 4048kbps or 512KB/s) upto a data transfer of 8GB, once the data threshold is reached, the speeds drop down to a mere 256Kbps (thats 32KB/s). Every month the system is reset and you get full 4mbps speeds for the first few days till the limit of 8GB is breached like in a few hours for example 10 hours provided you download at full speed.
With your present plan which costs 900+ you should be able to transfer a total of 8GB@4mbps + 72GB@256kbps = 80GB. If you shift to UL750 plans you shall be able to get around 110-120GB of data across. Your call !
Ha ha ha, BSNL Losers. Well then, i'm pretty much happy that they did this to me. Now will go for 750 Home Combo. Thanks everyone for your kind information and help. Will get back to you when Plan changed.
