HiI have installed a new wireless Router Beetel 450TC1 for my MTNL connection. It works fine except the automatic disconnect script isn't functioning well for it.Below is the script I used to use for the TKD318 EUI (which worked fine while I had that modem). I know that the command instead of reboot is "sys r" for the new modem and it works but am getting stuck on the password screen. I can use telnet manually and it works fine so all it needs is a bit of tweaking to the script. I connect using PPPoE and it has worked quite well for me.Can anyone help me ?192.168.1.1 23WAIT "login"SEND "admin\m"WAIT "password"SEND "admin\m"WAITSEND "reboot\m"WAITSEND "exit\m"
