Recommendation for unlimited broadband plan in India
  • Thread starter Thread starter rpg.314
  • Replies Replies 17
  • Views Views 5,614
rpg.314
None
I am looking for a broadband connection. Must haves for me are
[*]unlimited downloads
[*]Reliability of connection
[*]no speed X for Y amount, speed Z after that
[*]Availability in Ashok Nagar area of Pune
[/list]
Any suggestions would be highly welcome. :smile:
BSNL BB Home Combo UL 750 - 512 Kbps ULNo FUP BS. This is the best plan that suits your requirments. Go for it!I would advise you to stay away from Reliance and other ISPs like Tikona else you'll end up losing your night's sleep.
Thanks, how long does it typically take to get a BSNL connection. I ask because I moved here recently and don't have a landline either.
You can know the exact duration for getting new connection only from your exchange. If ports are available you should be online within 6-7 days.
whats your budget,so we can suggest accordingly and speed requirment?TATA TTML is the BESTEqual UPLOADSUnlimited without any Fair Usage PolicyVery Reliable
Firstly, visit your nearest BSNL CSC and apply for a landline. Your new landline will be installed in 3-4 days. Once the landline is in place, apply for a broadband connection. I suggest you buy modem/router from outside instead of buying from BSNL. Your new broadband connection will be activated in a week depending on your luck. These days most of the BSNL broadband connections are activated in a week as there is no waiting list like there used to be one couple of years ago!
Equal UPLOADS
Very Reliable
whats the cost? is it available in kerala?
tata plans are very expensive in kerala......
not having equal upload speed...
this speed test of 512kbps bsnl of SRK is better than Tata.
but i think i will not get 680kbps upload speed as SRK bcoz now i am using 500C of BSNL 2MBPS. now i am getting upload speed of about 700-800kbps. then how i get 680kbps upload speed for 512kbps plan..
