Reliance Jio Fiber upload speeds are 10% of your plan speed
  • Thread starter Thread starter undercover
  • Replies Replies 244
  • Views Views 33,466
@Nitin Currently, yes. The idea is that it can wirelessly support gigabit speeds, eliminating the need for gigabit ethernet. It supports 8 5ghz channels, thus creating more space for higher speeds (but again, limited spread)
AX will support 4*160 MHz channel, so ideal for 8k, VR streaming etc. Though I don't think either will stutter even on AC.
Challenge is lack of consumer grade AX hardware. Whatever is available is not really interoperable at 160 MHz at the purported speeds. As the SNB tests say, it's as good as AC currently, and unless we get better chips and stability, it's just another fad.
I am using 2 of Asus RT-AX88Us in AiMesh mode and the latest firmware which enabled WPA3 and OFDMA is pure trash. Wifi seems like from dark ages. Internet slows down to a crawl and at that time even router homepage also doesn’t open. Rebooting main router and mesh node is the only temporary solution till it happens again the next day. I was blaming my Hathway connection but soon found out that Asus’s firmware has been released without adequate testing. Kinda sad I paid around 50k for this setup and forced to beta test this new technology. Whoever is thinking of updating to Wifi6 based router needs to hold their horses for 3-4 months at least. These firmware issues need to be fixed first. Keep an eye on snbforums on Asus AX devices.
i am using archer C3150 v2 TP-Link, some problem in ipv6 connectivity with this model so they have asked 1 week for solution or will give higher version so from ac series to ax series, i hope for ax6000 as replacement if they don't find solution then i will have plenty of time to test wifi 6.
