Reliance Pro 3 WiFi Dongle (ZTE AC 3633)
  • Thread starter Thread starter x720
  • Replies Replies 157
  • Views Views 90,846
Reliance Netconnect+ has been rebranded as Reliance 3 after introduction of RevB services under the Pro3 brand. So, now, RevA instead of being Netconnect+ is called Reliance 3, and RevB is called Reliance Pro3.
Will check if the dongle works in my Asus router and report back.
Check for availability of Pro3 network before buying.
were u able to check whether the dongle works in the router ?
Sorry for the delayed reply, it doesn't seem to work with my Asus router with default setting. I usually use unlocked dongle, and I know the settings for that. Might have to tinker around a bit, to get this to work.
are u in mumbai circle ?
Reliance store guy says the unlimited plans are not available for these wifi devices and shop.rcom says these unlimited plans are only for mumbai circle
Does your circle have MTS? If so, I guess the circles in which rcom is using MTS' revB data network do not have unlimited plans. So much for their website not mentioning this.
Yep. Mumbai.
my circle has MTS , DOCOMO CDMA , and RELIANCE TOO
went ahead with the netconnect plan 449 unlimited for 15 days , but the balance shows 7 Gb
seems like my circle doesnt have the unlimited plan , trying to exhaust the 7Gb and see wat happens
