Settings for WA3002-G4
  • Thread starter Thread starter RMDesai
  • Replies Replies 76
  • Views Views 46,895
Remove the check mark at the bottom and try.
http://manu.k81.googlepages.com/wansetup.JPG
Tried that not working :(
I still don't know you are an old user with IP 59.xx.xx.xx or new user with IP 117.xx.xx.xx
I am having Ip starting with 59.xx.xx.xx
Point 4. WEbmail.Did you enter xxxxx in the first page ? or selected xxxxx @bsnl.in page. ?\"
Tried both ..not able to login
6.OK. Just confirm whether you are using USB port or LanPort/ethernet card.
7. Do you enter password in the dialer or is it already saved ? and hope you know it .
8. Just to confirm, your Id password combination is correct check your usage with DQUF program from sunish.net | - Thinkings of a tinker who thinks he's a thinker.
9.@rmdesai has connected same modem in "always on " mode. Send a PM and request him for help.Even Wireless set up he has done , I think.
Quote numbers only !!!!
@essbee
6. Lanport/Ethernet card
7. I am entering password, I know it.its working(its not saved)
8.With this program I am unable to login to site. I told already, am unable to check my account usage at any dataone sites. The BSNL techincian gave - http://10.0.0.45:8080/ as i have mentioned before. He says it will work tomarrow. I will check and confirm on that
9. Ok I will do that.Thanks
Manu
10.0.0.45.8080 is an invalid ip address.
what he meant is IP address 10.0.0.45 at port 8080 i think.even the old bsnl portal for new users(p3hosting) has this port 8080 at the end of link.i think that some sites use a specific port other than 80 for web traffic & for those sites link format is usually 123.456.7.8:8080 where 8080 is the port at the remote server hosting that site & through that port connection will be established.
you need to download the telnet script tool first Free Telnet Scripting Tool download
then you need to create a text file with the script to connect to your modem and restart
hi.. i have configured my modem in bridge mode.. will script will work for me.. please reply..
no dude.. works only with ppoe modeno wait.. actually not sure.. i think it may work with bridged mode as well.. cause restarting the modem disconnects the connection.. it can be used for that.. but u need to have a seperate script to dial the connection again
thanks for your reply.. what am i supposed to do to check whether its working or not...please tell me clearly...
hi.. i am using wa3002g4 only.. for the past three days i am unable to access in wireless mode.. it says the settings saved on this computer do not match the requirements for the network.. i found that the problem is with seecurity type.. if i keep the network authentication in open then it connects.. when i keep it in wpa mode then it is asking for radius server ip address.. what am i supposed to do.. please help me..
compare instructions for Wireless setup. For Reference : not exact. select WA3002 -G1 . calcuttatelephones.com/dataoneinstall/mu08.html
