is it necessary to use the jio modem for broadband connection. there must be many routers in the market that have optical network connection, isn't there?
@Shubham i saw you asking that connecting the ONT to a normal router with a 5GHz band via ethernet cable should help in getting better wi-fi speeds. did you try it?
You will get erratic speeds on 2.4Ghz no matter what. And stop blaming jio for that. It is how this band works. If you want consistency then go for 5ghz.
