Solved: Split AC 1.5 ton | Voltas
Delhi
Airtel & Vi
My Sharp inverter AC has a bad leak in the cooling coil. So it's time to get a new one. Many users have mentioned that Voltas is a good buy considering the 5 years warranty. Kindly suggest some models?
Solution
Looks like they have changed the extended warranty thing. Now you need to pay 2990 for it, however you get 10 services as well (I think?) so still a good deal
my parents have used Samsung, LG, Daikin, Sharp, Hitachi split acs at different points of time. None of them lasted more than 4-5 years. I guess it might be area specific as well since the issue almost always was gas leakage
Voltas and Carrier have both worked fine
Solution
I don't remember the details as the guy had no brochures or any price list. He just scribbled it on a tiny piece of paper without model number. But store prices are usually comparable or lower than online on ACs. So, it might be worth visiting the Voltas store first before ordering it online.
His number. Though I am not sure if dealers tell accurate pricing over phone lol.
