/members/sa1/
Welcome to broadbandforum.co
If there is a old junction box yellow ( not black ) with an RJ11 port ( having a small printed circuit board with one condenser resistance inside ) disconnect it . This is meant for surge/lightning arrestor.
Telephone line ===>>> RJ11cable to ===>>>
ADSL splitterLINE Port
Splitter Phone port ====>>> all phones including cordless base.
Splitter ADSL Port ======>>> Rj11 to modem.
The ADSL splitter replacement is also another option.
When you use the phone is the line noisy?
Can you check the SNR and attn data from your modem ? Mention model also.
My modem IS UTStarcom WA3002-g1 . Downstream SNR is 10( I have heard it should be 12+) and Attenuation is 35 Upstream SNR is 20.3 and attenuation is 27.3
As for your othr information can you please bother to explain it again.
I have nothing which is black or yellow. My splitter is grey. Is the standard telephone cable called RJ11?
Then perhaps the problem is that my other phone is connected before the splitter . But even when I disconnect it ,the problem persists. But I cannot remove the line itself because wiring is done inside the building.
When I use the phone,the connection is fine. Its when I DONT USE IT with receiver replaced that the problem comes up.
