Suggest ISP for FTTH
  • Thread starter Thread starter A^00P
  • Replies Replies 22
  • Views Views 4,404
I am mumbai based .apart from airtel/voda/tata/hathway above non of them provides services in Mumbai .even in my area it looks like hathway has almost monoploy .looks like i need to go with hathway only.
does airtel provides ftth .on net i read that what it basically provides is vdsl and not ftth ???
Also should i have my own router or should i go what is provided by lco/hathway. lco/hathway most probably would be providing router from Huawei... (based on their add)
If i need to buy one then which brand/model is good one
I have RailWire. The installation charges might be off putting though. Costed almost 4K for everything. But then, the LCO had to put up the wire from the nearest point which was more than a kilometer since my colony did not have any fiber.
Paying INR 949+GST for 75 Mbps/500 GB.
The speeds are consistent. Sites are blocked (just like others) but it's nothing a simple DNS change cannot overcome. There have been a few times when the connection was down this month because they are laying the cables underground but overall I am happy with it. However, if you have another ISP who is willing to forego the installation charges if you pay a couple months in advance, I suggest you try that.
Bro for bsnl ftth they asked around ₹7k+ for just wiring and then extra charges for installations.. Trust me 4k for 1km is nothing. 😁😁👍
Hi @happybanana , in which city
Its application process isnt straight fwd .One needs to send details through post.hope there was some kind or portal where one could apply directly
Also can we know who are there local LCO are
Railwire do have very good routing. Back here in kerala my friends used to get very low ping on their services if it's available just go for it 👍
Airtel FTTH > ACT Fiber > JioFiber > Hathway Fiber
Choose Airtel if that's available.
Take any plane + 299 Unlimited Data Recharge (Newly Introduced) and you don't need any other ISP.
Airtel has best Routing and Stability. Customer Support is Top Notch.
ACT Fiber has some routing and drop connection issues confirmed by 3-4 friends of mine who plays Counter-Strike and Streams.
JioFiber is good but the only issue is FUP. (Routing is getting improved regularly, as they are new it will take time for them to improve routing)
Hathway is good and cheap if it's available in your area. Problem with them is poor customer support, unreliable stability (they take data bandwidth from Airtel and they go out of data multiple times).
Choose airtel anytime my local isp provider had airtel first was very stable.
From past two months they are routing through Tata and it ain't good.
So far speeds remain moreover same or maybe bit more in airtel.
But tata routing is messed up over here it keeps fluctuating and it's not good for playing online multiplayer games.
ok turns out airtel doesnt provides FTTH services in my aera. looks like either mtnl or hathway let see what is in store in future
even Tata Sky is not offering services in my aera...
Waiting for update from voda/you broadband
ps : even voda/you broadband is not available
Similar to my situation where I only have BSNL (ADSL and FTTH) in my home area :D No other ISP option at all so I am stuck with BSNL only.
If your MTNL or Hathway are the only options then go with the ones who provide fiber FTTH. Even MTNL FTTH will be better than Hathway if Hathway not providing fiber.
So i was just wandering In city like mumbai you have an area where 3 popular services providers are not providing there services (can be any reason from profit to safety of their equipment from LCO) .What you happen remote corner of country/village
Suddenly i am like thank god for psu like mtnl/bsnl...
Also It just like how hathway had nearly monopoly in my area
@vishalrao both are providing now needs to select one of them
