Taking BSNL, Help!
  • Thread starter Thread starter Shad0w
  • Replies Replies 2
  • Views Views 1,170
Shad0w
TATA
hey there, I've finally decided to take BSNL Home 500. I'm at Trivandrum, Kerala now. I hope I wont have any "disconnections" during the free times like many others!! :( Can you guys tell me what is the difference between these 4 modem types?Which one should I select - Type -I, II, III, IV? Also, Does BSNL block any ports?
please see this link
it is better to opt for modem type IV - so that you can easily
add a laptop or another computer to your internet connection .
AFAIK , BSNL is not blocking any ports !
BROADBAND MAIN MENU
Bharat Sanchar Nigam Ltd.
Add these two sites to your Favorites.
On rent :only Type 1 modem given on a rent of Rs 60 PM.
.If you have only one computer this will do.
To my knowledge BSNL does not block any port.
You may also need to check your day usage
sunish.net | - Thinkings of a tinker who thinks he's a thinker Dataone Quick Usage finder ..
If you are using FireFox browser DataFox is a very good program to check your usage.
See the beginning of this . forum
And to check speed SpeedGuide.net :: Your Guide to Broadband recommended.
Finally the modem is only part of the internet setup and don't expect scorching speeds. all the time. for your downloads !
