Unique Problem
  • Thread starter Thread starter Shantanu15
  • Replies Replies 9
  • Views Views 2,892
Shantanu15
BSNL
Hi guys,
I have been facing this frustrating and yet due to lack of any obvious solutions a unique problem for some 3 months now.It all started when i had an inverter installed.My adapter that comes with MT882 stopped working since that day.Apparently it got fried as there was several cases of overloading when they were installing the inverter.
Anyhow,I went and got myself an adapter which was no easy task as an adapter of 9v 1amp configuration is pretty rare,(got plenty of 9v 350mamp),now comes the interesting part my modem works only when the inverter is on,when normal power resumes the modem automatically resets,i.e the green power light will flash and the orange light will flash and the process repeats.
The most obvious thing is that the adapter was not of the std rating so i got myself another one,but the problems persists.So Guys I am left with two options either get myself another adapter in which case i would be grateful if u could suggest certain brand names or get another modem,I would appreciate if u could give some modems which work with dataone and preferably come with a price tag of less than Rs.1200.
And one more thing on good days,probably when the voltage is just about right the ADSL green light blinks for about 20 sec as if about to make the connection and the stops blinking throwing my hopes in abyss again.Help Please!!!
@shantanu15
Welcome to broadbandforum.co
Sorry to hear about your troubles, but participants in this forum will try to
solve your problems.
FIRSTLY check up the old MT882 power adaptor given by BSNL. Both the input and output9V are AC . Usually when DC output is available the plug will be marked inner + ve. etc.
The rating for this is 9V AC 1000 ma. with
The electronic circuit inside the modem may not have a transformer and only a regulated bridge circuit for converting to DC.
When AC 9V is given the DC could be 12 V for the modem functioning. I am checking up the specs.So a " DC adaptor" rated for 9VDC 1A can be tried .
Or to be on safe side get a step down transformer for ratings.220-230 AC output 9V 1amp.
Regarding modem if on rent, ( if purchased also) get it exchanged at BSNL. Here in Chennai they test and then replace the power unit or modem. TRy your luck.
SEE this thread ALSO: Your feedback will be greatly appreciated.
https://broadband.forum/bsnl-dataone-broadband/24369-power-cuts-modem-restarts-annoyance-continues/
Thanks for the reply essbebe,you're right the power supply is 9v1A AC,as for the 12V required for it's functioning you may be right,Actually i had bought one of those multivoltages adapters and when i increased the voltage the voltage upto 12 V,the modem actually worked.But then that adapter gave way too (don't know what is with this place??),and i didn't try it again fearing i may end up frying my modem.It would be a big help if u could tell me whether I can use upto 12V safely or not.Thanks again.
point 1 :
Good: confirms that MT882 needs /9V/or 12VDC.internally. .
Because when you give 9VAC after rectification it can go upto 13.5 V DC (1.45times of 9v stabilised around 12Vdc). With DC input stepping up is not possible.
Presume you were using the "AC to multi DC adaptor with the yellow knob!"
The current rating must have been be low and they normally use only a single DIODE/electrolytic condenser and with taps IN SECONDARY OF THE TRANSFORMER.
and there will be wide variation in DC OFFLOAD/ONload.
Para two :
NO .I am not SURE whether what voltage conditioning is done inside the modem, and the DC requirement for the board.
ANY DC supply 9V max 1amp rating can be connected safely. If it does not work, then 12V DC at 1amp at your OWN RISK .
PARA THREE : YOU can try, or give me a day or two to try with my MT882modem
9VDC or 12V DC.
instead of 9V AC at 1amp. as input power. ( original adaptor supplied by BSNL)
Set up with safety features will take some time.
Para FOUR:
Please give details about your "inverter." Is it like the one we use for Fridge AC etc or UPS ?
and present status of your Internet use.Modem will disconnect when invertor adjusts the
output voltage. That is why I have suggested seperate battery system ONLY for the modem.
see other thread.
Thanks for the reply essbebe,By inverter i mean the one which supplies the back up power to the whole house.I have plugged in my adapter to the UPS(exclusively for my PC) which in turn derives it's power from the "inverter" in case of power failure (connected to a power point to which inverter supplies power) and not it's own battery as it lasts for 20 min max.
What has been puzzling me is that what is it with the inverter supplied power that my modem works without any hassle but goes on resetting when normal power resumes.The most obvious thing is that it must be some voltage problem but after changing three adapters the situation remains same so it make me wonder if there's something wrong with my modem.Also there is hardly any noticeable voltage difference b/w the normal and inverter supplied power.
If this was not confusing enough then check this out,even in inverter supplied power(when lights are out) the modem would work normally only for about 20-30 mins after which the link gets broken(not reset) if i connect it straight to a wall plug,but would work like a charm if i connect the adapter to my UPS which itself is deriving power from the inverter.the only plausible explanation is that maybe the UPS stabilizes the voltage.But this is as lame as the problem is frustrating.
As for going to BSNL office,they won't consider replacing this set as i had bought this modem and the warranty period of one year has long gone.I somehow managed to call their engineer to take a look but at the mere sight of a different adapter,he said that it's the adapter's fault.
Therefore I asked in my first post that will any other modem available in the market would work with Dataone and will it be cheaper than Rs. 1200 or not cause you might understand my frustration that while the whole country prays for the power to be regular and uninterrupted,I on the other hand want the lights to go out so that I can atleast check my mail....
for 1200 rs. bsnl provides some decent modems(siemens c2110 is usually given now-a-days).seeing your problems i would say take a modem from bsnl on rent for a month.
Thanks whitestar,that is probably the only option left but before shelling out 1200 bucks i'd play around with the adapters as essbebe has suggested and then if nothing works out I'd probably go for a new modem
you don't have to shell out 1200 straightaway.1200 will be deposited as security & modem rent is rs60 per month.if you decide to buy the modem later you can buy it with the security deposited.
members/shantanu15/Sorry to hear about power supply problems . During summer it is going to be worse, with everybody switching on their AC's. in the Capital Region. Another member is getting his old MT882 exchanged for similar problem.Please wait for updates.Para two : There is nothing , that prevents you to ask for a Modem on rent with new Adaptor!.Rental Rs 60/pm plus 12.5 taxes. ... Deposit Rs 500 only. Check . Then decide future action !!!!!
