  • Featured
  • Replies Replies 208
  • Views Views 66,809
Username: ONTUSER
@Skeeter, nope, ONT equipments can be upgraded from any vendors olt. except some specific models. i was able upload fw to a zte f670l ont from olt and got full access. so similarly i want to give it a try upgrading from olt.
As i found out the hard way, little heads up to everyone
Never set your ONUmode to 0000, even if you set it, don't hard reset
this is the shell ritool dump after changing to 0000 and before hard reset
the Format:01
the MfrID:ALCL
the Factorycode:02
the HardwareVersion:3FE48299DEAB
the ICS:01
the YPSerialNum: B404F06C
the CleiCode:0000000000
the Mnemonic:G-2425G-A
the ProgDate:221207
the MACAddress:4c:06:17:15:62:4c
the DeviceIDPref:0000
the SWImage:005e
the OnuMode:0002
the Mnemonic2:A
the Password:00000000000123456789
the G984Serial:b404f06c
the HWConfiguration:0000000000000000
the PartNumber:3FE48300BCAA
the Variant:AA
the Spare4:000000000000000000000000
the Checksum:5ceb
the InserviceReg:0000
the UserName: userAdmin
the UserPassword:usradmin
the MgntUserName: adminadmin
the MgntUserPassword: ALC#FGU
the SSID-1Name:0000000000000000
the SSID-1Password:00000000
the SSID-2Name:0000000000000000
the SSID-2Password:00000000
the OperatorID:0000
the SLID:00000000000000000000000000000000
the CountryID:i1
the GroupID:00000000
the Checksum1:f4e6
the Spare6:0000
the RollbackFlag:0000
To change Back BRTI
if anyone can make sense or anyway to rollback, give suggestions.
Hi Brother @Rehan ahmad i below device and i have tried with the ONTUSER method like username as ONTUSER and password as "anyrandompassword" which is not working Password Invalid error and i have tried with another with encrypted password like below ....
<TelnetSshAccount. n="TelnetSshAccount" t="staticObject">
<Enable rw="RW" t="boolean" v="True"></Enable>
<UserName ml="64" rw="RW" t="string" v="admin"></UserName>
<Password ml="64" rw="RW" t="string" v="OYdLWUVDdKQTPaCIeTqniA==" ealgo="ab"></Password>..
But i am facing error in login with shell password2 : '; /bin/sh; # getting Invalid error. Please help me to unlock my router
C:\Users\Amir\Nokia>python nokia.py -u config.cfg
-> little endian CPU detected
-> fw_magic = 0xffffffff
Traceback (most recent call last):
File "C:\Users\Amir\Nokia\nokia.py", line 137, in <module>
xml_data = zlib.decompress(compressed)
zlib.error: Error -3 while decompressing data: incorrect header check
