  • Featured
  • Replies Replies 167
  • Views Views 56,026
Username: ONTUSER
I have unlocked successfully but BRASinfo.txt read failed in log.
Unable to connect other local fiber.
Only work for the first time after reboot it's not working.
Anyone having solution to this ?
config.cfg, import in your router is not importing file , please help.
It same as Nokia in term of speed but range excellent no 5g drop issue like in nokia, only issue is it take 1 min to restart when electricity shift from main to invertor.
Since im on 300mbs plan,
Well I want to make mesh and i don't wanted to plut so many devices and wire. After lot of "R&D" i came to this conclusions.
For mesh wifi - router are best vs little mesh pod (in term of price and range and speed)
Xc220 v for 2200
Next month i will either buy TP-Link c6 or c64 for easymesh setup (tp link onemesh doesn't support two router and those little extender are over price in term of range)
i messed up my ont running 3FE49362JJIJ50 firmware. i changed the operator id to 0000 and set onumode 0002 and then did factory reset from web. now i lost cli access. saying wrong password. export and import config is not visible anymore when logged via web and wan settings are being saved. can anyone please provide stock firmware, i have access to olt, i will try to update from olt.
