  • Featured
  • Replies Replies 208
  • Views Views 66,809
Username: ONTUSER
I can see neighboring APs have no options to connect with them through the portal:-
For the Mesh, the page looks like this:-
Any instructions on this can help me better in trying those ways.
Thanks.
PS: the password has to be encrypted ('admin' in below example)and add field as shown below
<Password ml="64" rw="RW" t="string" v="OYdLWUVDdKQTPaCIeTqniA==" ealgo="ab"></Password>
Secondly keep the file name as config.cfg of the packed file to ensureupload
i am unable to upload the new config, The import button on click goes white and no remarks are shown next to button after selecting newly encrypted file.
Device Name
G-2425G-A
Vendor
Nokia
Hardware Version
3FE48299DEAC
Boot Version
U-Boot-Dec-31-2016--12:00:00
Software Version
3FE49362JJIJ54
before exporting config from router
before encrypting the config, followed below steps
am i missing something
I've managed to unlock my ONT with the guide, thanks! But when I enable bridge mode, it's not linking connection. I tried PPPoE on my OpenWRT router & PC. It never worked and always showed either User_Request_Error or Connection Failed on my OpenWRT. On PC it showed "failed to connect."
Any workarounds?
