  • Featured
  • Replies Replies 167
  • Views Views 56,032
Username: ONTUSER
hello anyone helps me i am facing error
PS C:\Users\The Lost Gaming Club\Desktop> python Nokia.py -d OYdLWUVDdKQTPaCIeTqniA==
Traceback (most recent call last):
File "C:\Users\The Lost Gaming Club\Desktop\nokia.py", line 221, in <module>
print('\ndecrypted: ' + RouterCrypto().decrypt(base64.b64decode(sys.argv[2])).decode('UTF-8') + '\n')
File "C:\Users\The Lost Gaming Club\Desktop\nokia.py", line 50, in init
from Crypto.Cipher import AES
ModuleNotFoundError: No module named 'Crypto'
PS C:\Users\The Lost Gaming Club\Desktop> pip install pycryptodome
Requirement already satisfied: pycryptodome in c:\users\the lost gaming club\appdata\local\programs\python\python311\lib\site-packages (3.18.0)
@sanketrohilla Try using pip3 instead of pip, as you are already using python 3 instead of python 2.x
@Rehan ahmad It appears Airtel has upgraded the firmware. It is new connection, so new router and my router currently runs 3FE49362JJIJ54. The config file was decrypted, edited, encrypted and then imported. However, I am unable to use the password I set during the ONTUSER's password step. It keeps saying incorrect password. I tried repeating the entire process and changing to a different simple password and it was rejected as well. Unsure if it is caused by the firmware update. Thought I would let you know. Thank you for all the help you have provided thus far.
Edit: I was wrong. This seems to work for the latest firmware as well. I was required to enable to the Telnet SSH Account in the xml file as well by changing the false value to true. I seem to have overlooked that.
I have unlocked the router, Can I use it as a repeater by connecting to my primary router wirelessly? It lists neighboring AP (Access Points) but does not provide any option to connect with them. (I can't connect my two routers with an ethernet cable as I need to set them up on two different floors).
I already have the updated version of firmware having the option to mesh, I am trying to put the serial number of the router into Beacon serial number field but it's not working, Do I need to convert my secondary router into a beacon? Any documentation or leads on this will be helpful.
Thanks.
