  • Featured
  • Replies Replies 208
  • Views Views 66,809
Username: ONTUSER
@Rehan ahmad
I have successfully done this.
My config XML bit looked like this:
<TelnetSshAccount. n="TelnetSshAccount" t="staticObject">
<Enable rw="RW" t="boolean" v="True"></Enable>
<UserName ml="64" rw="RW" t="string" v="ONTUSER"></UserName>
<Password ml="64" rw="RW" t="string" v="harsh" ealgo="ab"></Password>
</TelnetSshAccount.>
and set <LimitAccount_ONTUSER rw="RW" t="boolean" v="False"></LimitAccount_ONTUSER> to false as you can see.
When I login, I get "###Login incorrect" issue. Password is 100% correct, no caps, tried copy paste, tried typing. Tried it all. Not working? Is this patched too?
EDIT: I solved the issue. "harsh" was not good enough apparently, it never worked. Setting a password to more than 8 characters worked.
