  • Featured
  • Replies Replies 167
  • Views Views 56,045
Username: ONTUSER
what can i do there is no option for backup and restore
Hey already my Nokia router showing Latast Firmware.
My problem is , i m unable to ping my router ip from outer network.
It was working 2 years back, but now i heard that Airtel blocks pinging IP & ports from WAN.
so is there any way to solve this, bcz i m using DDNS and my port forwarding is also not working, so plz help me with this problem.
Hi All, have followed this guide and successfully unlocked my Nokia G2425A. Now i want to setup voip on PC for which i need both Internet and VOIP to pass through to my bridged router, and the bridged router will handle the vlan tagging/untagging
Issue is I am unable to pass both voice and internet through Lan 4(bridged port from backed), and when i enable vlan in my router the connection disconnects.
My setup - Airtel Static IP, Nokia G2425A unlocked, bridge mode enabled on port 4
