This can happen if your area is still not upgraded to 500 or 1 Gbps. Find out from the local team if it is possible. When I called for an upgrade the call centre said its possible but the local TSBB tech I know said no, it is still in testing phase and he'll let me know when done. There's a disconnect between the 2 teams. The OLT has to be configured to support 500+ MBps only then will it happen even if your app says you are on the new plan
@Chip
Yeah. But after creating a rukus, they finally upgraded my area for 1 Gbps the next day. Now I get constant 530 Mbps up/down while downloading anything. I don’t use torrents though.
@Chip You can upgrade midway. That’s what I did. Just pay the difference. New plan gets activated for the duration you ask them for. The amount calculations were correct in my case.
@tatyasky thanks, yes I am aware of the midway upgrade but my Airtel connection is coming for renewal in a week so will probably upgrade TS next month.
