Usb Prot For Broadband
sanjoymandal
if i am using a USB port to assess the broadband do i need to install a LAN card for my desktop?will i be able to connect to the USB port and use straight away?thanks
^ if you want to use USB port for broadband then
there is no need of LAN card to be installed .
However , LAN connection is prefered as it is more
stable and Less problematic . And Good quality LAN
cards are available for about Rs 250/- only .
also u will have trouble with the usb if u wanna use another os like linux.. u wont have to install drivers for ur lan card in most cases as it will get detected automatically
hi bhinderthansk for the helpwas initially reluctant to disturb my CPU, opening it up ...but now have decided to install a LANthanks
