Using bsnl broadband without splitter
@shubham ken rawat
Thanks for your help and
i want to know how u got to knew that i am close to exchange?
Your modem's attenuation data.
[TD="class: hd, bgcolor: #E0E0E0, colspan: 2"]Mode:[/TD][TD="bgcolor: #FFFFFF"]ADSL2+ [/TD] [TD="class: hd, bgcolor: #E0E0E0, colspan: 2"]Line Coding:[/TD][TD="bgcolor: #FFFFFF"]Trellis On [/TD] [TD="class: hd, bgcolor: #E0E0E0, colspan: 2"]Status:[/TD][TD="bgcolor: #FFFFFF"]No Defect [/TD] [TD="class: hd, bgcolor: #E0E0E0, colspan: 2"]Link Power State:[/TD][TD="bgcolor: #FFFFFF"]L0 [/TD] [TD="bgcolor: #FFFFFF, colspan: 3"] [/TD] [TD="class: hd, bgcolor: #E0E0E0"] [/TD][TD="class: hd, bgcolor: #E0E0E0"]Downstream[/TD][TD="class: hd, bgcolor: #E0E0E0"]Upstream[/TD] [TD="class: hd, bgcolor: #E0E0E0"]SNR Margin (dB):[/TD][TD="bgcolor: #FFFFFF"]33.8 [/TD][TD="bgcolor: #FFFFFF"]10.6 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Attenuation (dB):[/TD][TD="bgcolor: #FFFFFF"]19.5 [/TD][TD="bgcolor: #FFFFFF"]36.7 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Output Power (dBm):[/TD][TD="bgcolor: #FFFFFF"]10.3 [/TD][TD="bgcolor: #FFFFFF"]0.0 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Attainable Rate (Kbps):[/TD][TD="bgcolor: #FFFFFF"]26656 [/TD][TD="bgcolor: #FFFFFF"]388 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Rate (Kbps):[/TD][TD="bgcolor: #FFFFFF"]2044 [/TD][TD="bgcolor: #FFFFFF"]413 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]MSGc (number of bytes in overhead channel message):[/TD][TD="bgcolor: #FFFFFF"]64 [/TD][TD="bgcolor: #FFFFFF"]38 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]B (number of bytes in Mux Data Frame):[/TD][TD="bgcolor: #FFFFFF"]14 [/TD][TD="bgcolor: #FFFFFF"]21 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]M (number of Mux Data Frames in FEC Data Frame):[/TD][TD="bgcolor: #FFFFFF"]1 [/TD][TD="bgcolor: #FFFFFF"]8 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]T (Mux Data Frames over sync bytes):[/TD][TD="bgcolor: #FFFFFF"]4 [/TD][TD="bgcolor: #FFFFFF"]1 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]R (number of check bytes in FEC Data Frame):[/TD][TD="bgcolor: #FFFFFF"]16 [/TD][TD="bgcolor: #FFFFFF"]14 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]S (ratio of FEC over PMD Data Frame length):[/TD][TD="bgcolor: #FFFFFF"]0.2309 [/TD][TD="bgcolor: #FFFFFF"]12.9915 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]L (number of bits in PMD Data Frame):[/TD][TD="bgcolor: #FFFFFF"]1074 [/TD][TD="bgcolor: #FFFFFF"]117 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]D (interleaver depth):[/TD][TD="bgcolor: #FFFFFF"]128 [/TD][TD="bgcolor: #FFFFFF"]2 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Delay (msec):[/TD][TD="bgcolor: #FFFFFF"]7 [/TD][TD="bgcolor: #FFFFFF"]6 [/TD] [TD="bgcolor: #FFFFFF, colspan: 3"] [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Super Frames:[/TD][TD="bgcolor: #FFFFFF"]54046 [/TD][TD="bgcolor: #FFFFFF"]51390 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Super Frame Errors:[/TD][TD="bgcolor: #FFFFFF"]2 [/TD][TD="bgcolor: #FFFFFF"]20 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]RS Words:[/TD][TD="bgcolor: #FFFFFF"]15133092 [/TD][TD="bgcolor: #FFFFFF"]268207 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]RS Correctable Errors:[/TD][TD="bgcolor: #FFFFFF"]348 [/TD][TD="bgcolor: #FFFFFF"]637 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]RS Uncorrectable Errors:[/TD][TD="bgcolor: #FFFFFF"]233 [/TD][TD="bgcolor: #FFFFFF"]N/A [/TD] [TD="bgcolor: #FFFFFF, colspan: 3"] [/TD] [TD="class: hd, bgcolor: #E0E0E0"]HEC Errors:[/TD][TD="bgcolor: #FFFFFF"]1 [/TD][TD="bgcolor: #FFFFFF"]26 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]OCD Errors:[/TD][TD="bgcolor: #FFFFFF"]1 [/TD][TD="bgcolor: #FFFFFF"]0 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]LCD Errors:[/TD][TD="bgcolor: #FFFFFF"]0 [/TD][TD="bgcolor: #FFFFFF"]0 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Total Cells:[/TD][TD="bgcolor: #FFFFFF"]4212923 [/TD][TD="bgcolor: #FFFFFF"]565154 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Data Cells:[/TD][TD="bgcolor: #FFFFFF"]74277 [/TD][TD="bgcolor: #FFFFFF"]15563 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Bit Errors:[/TD][TD="bgcolor: #FFFFFF"]0 [/TD][TD="bgcolor: #FFFFFF"]1965 [/TD] [TD="bgcolor: #FFFFFF, colspan: 3"] [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Total ES:[/TD][TD="bgcolor: #FFFFFF"]6 [/TD][TD="bgcolor: #FFFFFF"]11 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Total SES:[/TD][TD="bgcolor: #FFFFFF"]2 [/TD][TD="bgcolor: #FFFFFF"]6 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Total UAS:[/TD][TD="bgcolor: #FFFFFF"]67 [/TD][TD="bgcolor: #FFFFFF"]0 [/TD]
How to Change mod mode to GDMT and Enable Bitswap ?
need modem/model/make/number
or
screenshot of Device info.
Usually under Advance options DSL sub menu.
NR Margin (dB): 33.8 10.6
Attenuation (dB): 19.5 36.7
Output Power (dBm): 10.3 0.0
please report above data again
Presume you unchecked box adsl2 +
It is possible to Upgrade the FW to latest at AT YOUR RISK ! {/color]]
[TD="class: hd, bgcolor: #E0E0E0"]SNR Margin (dB):[/TD][TD="bgcolor: #FFFFFF"]33.3 [/TD][TD="bgcolor: #FFFFFF"]8.7 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Attenuation (dB):[/TD][TD="bgcolor: #FFFFFF"]7.5 [/TD][TD="bgcolor: #FFFFFF"]5.5 [/TD] [TD="class: hd, bgcolor: #E0E0E0"]Output Power (dBm):[/TD][TD="bgcolor: #FFFFFF"]10.3 [/TD][TD="bgcolor: #FFFFFF"]0.0 [/TD]
