Using Personal WiFi router with Tikona
Hi all,
I am using Tikona broadband connection and bought a compatible wifi router should i connect LAN wire coming from terrace nano station directly to the router's WAN port or to the power supply adapter then the WAN port...?HELP
Nano Station > Power Adapter > Router
Im using a belkin54g router and my net works fine up to a point that after every interval it disconnects and i need to login in the tikona page again. Any suggestions to what might be wrong!
@Mayank, i too face this issue when power outages are there. Possible reason could be.. if there is a longer inactivity period (not downloading/uploading anything for say.. 10-15 mins), the connection might go off and you have to relogin.. but i dont think my point of reasoning is very valid.. but i have seen that.. when i dont have power cuts, and keep the bandwidth active.. i dont have the disconnection issue. The other possibility would be (most likely.....!!!) the Tikona network issue.. i see that their infrastructure servicing is very poor although capability wise its excellent.
Tikona internet auto-logouts after a certain time of no activity. It is a safeguard against unwarranted billing and data consumption.
The only way out is to have Static IPs for your connection, which cost Rs 1000/yr. The login page step gets eliminated using this.
i get the point i have a Dynamic IP, as far as inactivity is concerned i download stuff all the time and surf so wen im downloading stuff it loggs off. I am guessing ur suggesting to changing it to static IP by telling them. They said if u take our router u wont face any problem like this , Can this be a MAC addressing problem.
Thanks ...Should the router be 1. Dual-band or Single-band ? If Single-band , which band (2.4 GHz or 5 GHz)? 2. With Modem or Without Modem? 3. Advantages of With Modem over Without Modem router? 4. Bandwidth of Router?
Follow these steps in this order for D-Link 2730 modem, for setting up both as a LAN router and Wifi Access Point. Connect the LAN cable to LAN1 port on router and login to router ip (192.168.1.1) for doing these setup. Login with admin/admin as userid/password.1) Advanced Setup-> Layer2, Add atm0 with default settings2) WAN Service -> Add with Bridge type selected, keep others default3) Wireless ->Enable Wireless, and give your own SSID, keep others default4) Wireless-> Security-> Give Network Authentication as WPA-Personal, and passprase will be your own password to connect to WiFi5) Interface Grouping -> Give a group name as WAN, and select WL0, LAN2, LAN3, LAN4 from right to left, Apply/Save. Now there should be 2 groups one Default with LAN1 and other with new Group Name6) LAN -> In the right top dropdown select WAN group and disable DHCP, Apply/Save7) Management->Settings->Backup your settings8) Management -> RebootConnect the output from Tikona to LAN2 port on the router, connect your laptop to Wifi on the router using the SSID/passphrase. This should work, else shutdown router for 10 seconds, disable your wireless network and log-off/on again, enable wireless network and try connecting again.After this the ethernet wire coming from Tikona should be connected to LAN2 port, and you can use wifi. Note that LAN1 port is used to connect to the router only (192.168.1.1) after this setup. Go to login page of tikona (1.254.254.254) with ur userid and password given by tikona and login to connect to internet.RegardsShashi
