Using the Dlink 2750u as a true Ethernet WAN router
  • Thread starter Thread starter Manoj Mathew
  • Replies Replies 288
  • Views Views 329,713
Check D-Link DSL-2750U Deals on: Flipkart | Amazon | Snapdeal | Infibeam
I'd actually already posted on how to use the D-Link 2750u as a full fledged Ethernet WAN router, but it was a few pages deep in a Tikona thread and some users were getting the actual method mixed up with workarounds posted earlier in that thread.
The 2750u is actually capable of both adsl and Ethernet WAN routing. However the Indian firmware only enables the adsl WAN. So one needs to use the Middle East (ME) or Russian (NRU) firmware to enable the Ethernet WAN function (with the ME/Russian firmware one can use adsl, ethernet or 3g WAN). Please check the label under your router to identify the specific hardware version and apply the firmware that corresponds to it. Warning: You may brick your router if you apply the wrong firmware. Presently ME firmware is available for C1 and U1 versions. NRU firmware is available for C1. The NRU firmware has the mac cloning feature so you need not ask your provider to reset the mac lock (if mac lock is present). Here are the links
ME C1 v1.3
ME C1 latest
In the latest firmware, I'm having a problem getting my 3g dongle to work, which is why I've posted both versions. Once the firmware has been changed to the ME type, one can easily switch between versions (of the same hw type) using the software update page and one can choose which version works best for them.
ME U1
6.52 MB file on MEGA (Use 7zip/Winrar etc to extract firmware)
NRU C1
Applying the firmware
The firmware may not be accepted in the normal firmware update mode. Then you'll need to update it in the dlink crash recovery mode using a LAN cable (not wirelessly). Assign a static address on the PC for the ethernet interface in the 192.168.1.x series for eg 192.168.1.5
Switch router off, press the reset button ie insert ballpoint pen in reset hole under the router, keep holding the reset button and turn on the router. Keep holding the reset button for about 12 seconds after you power on the router. Now you'll see that the power led has turned red signifying that the router is in crash recovery mode. When you enter the address 192.168.1.1 on your PC browser, you find the upgrade firmware page. Just browse to the downloaded firmware file and flash!
After the new firmware has been flashed, your internet connection will not start working automatically, you will also need to set up the router correctly. Please do not apply any workarounds mentioned in other threads such as interface grouping, disabling DHCP etc
Instructions for setting up the C1 hw version router with ME firmware
Step 1:
Log into your router and under Advanced setup->Layer2 interface->ETH interface create an Ethernet interface with connection mode as default. Then go to Advanced setup->WAN Service and add service for eth0/LAN4.
Step2: If you have an internet connection with pppoe dialing such as pacenet, Honesty etc, in the next page, choose pppoe and put in username, password and service name in the next page. Also choose to enable NAT. In the next page move eth0 from available to selected gateway interface (if it's not already in selected) and remove ppp0 (if present) from selected, in the next page do the same for DNS and finally apply/save. Do thisonly if you have both eth0 and ppp0 appearing in the setup, else let ppp0 remain in selected.
Step2 (alt): If you have a connection such as Tikona, Reliance metro, cable internet (without pppoe dialer) etc, in the next page choose ip over ethernet, in the next page let the setting remain at Obtain an IP address automatically, in the next page check option to enable NAT, in the next page move eth0 from available to selected gateway interface (if it's not already in selected) and remove ppp0 (if present) from selected, in the next page do the same for DNS and finally apply/save. Do this only if you have both eth0 and ppp0 appearing in the setup, else let ppp0 remain in selected.
Step3: Then in advanced setup - 3g connection select primary uplink as ethernet.
Now connect your internet cable to the LAN port 4 of the router and you should be able to connect through any device connected through wifi or any of the other LAN ports. If you have a connection with a browser login such as Reliance metro or Tikona, the login page will show up only on the first device that you connect in each session. After you have logged in on any device, all other devices will have internet connectivity without going through the login page.
Instructions for setting up the U1 hw version router
In Internet setup, set WAN access type to Ethernet and in protocol, choose dynamic ip for connection such as Tikona, Reliance metro, cable broadband (without pppoe dialer) etc and choose pppoe if you have a pppoe dialer based connection such as pacenet, honesty net solutions etc. When setting up the internet connection, vlan id must not be given any value other than 0.
Instructions for setting up the C1 hw version router with NRU firmware (Port 1 is WAN port)
After you flash the interface will appear in Russian. Click on the rightmost dropdown at the top of the page and choose English to change the interface language.
Click on Advanced Settings at the bottom
Click on Interface Grouping in the Advanced section. Right click on the LAN icon on the right and click on setup speed and stream. There's some quirk in the interface and it's a little tricky getting this click right. Set duplex and speed to auto and save. Again hover mouse over LAN graphic and click on Make WAN. With the default option of 'Single service...' click save. Go back to the advanced settings screen. In the Net section click on WAN and add a connection. Choose connection type accordingly and choose LAN as the interface. Change MAC if required (if provider uses mac lock), (mac cloning doesn't seem to work) put in other details as needed (make sure NAT stays enabled) and click save. Internet cable goes into port 1 and not port 4 as in the case of the ME firmware
If your provider uses a mac id lock, plug in the internet cable in port 4 (port 1 for Russian fw) after completing the setup and ask him to register the new mac in his database.
Any users seeking help on this thread, please provide all relevant details (provider, type of connection) and screenshots (info and setup). Also please make absolutely sure that it's not a mac lock issue, as many users are needlessly seeking help on the forum without having got a proper mac reset from their provider.
I think even if that service name were editable, it does not really correspond to the pppoe service name that is used for making the connection. It's merely the WAN service name tag that D-Link associates with it. The actual relevant field should have been present in the PPP username and password section, but it's missing. The service name field is available in the C1 firmware pppoe settings.
Maybe you could monitor this page and check when new firmware is available that might fix this.
http://www.dlinkmea.com/site/index.php/site/support?pid=232
Alright thanks. For now, the internet is working just fine so hopefully it continues that way. If there's any issues, I'll be sure to check for new firmware and/or figure something out from the provider.
You're welcome and I wish I could have been of help.
You might run into problems if more than one service names are made available in the pppoe access concentrator and the Honesty one is not the default at your cable provider's end.
Hi Manoj,
Sorry I wasn't able to work on router yesterday.
Got through all steps of Russian Firmware, this time luckily I was even able to see the pop up when I click on Setup speed and... however in the last step where we have to enter WAN details,(MAC Address, username, password), As I click on save I get the error: Device Unavailable (Please see screenshot https://imgur.com/Agf9pHW )
After that even after I refresh the page or I closing and reopening the browser, the MAC address has still not cloned. It shows the same old MAC address, and as you said it shows LAN MAC address + 2 as WAN MAC address.
You're right, it just doesn't stick. I guess the only thing you can try is to ask the provider to add the LAN+2 mac. And then check with both Russian and ME fw.
Sorry for giving you false hopes!
Oh alright,
No no, please don't be sorry. You have been excellent help.
I will talk to ISP guys to get MAC address added. Thanks for helping me out in finding the correct MAC address to be provided to ISP though.
Deep S
I have update DSL-2750U U1 with FW ME_1.11,its updated.
and also i have done the ethernet setup as mentioned in the post,but still ubable to connect to net.
Internet LED on device is red.
My ISP is Asianet and its dynamic ip i can connect the RJ45 from my cable modem to any laptop.
Please let me know if settings are proper,screens attached.
https://imgur.com/eBx48AG
https://imgur.com/3cpDi31
Do not try with both 3g and e-wan at the beginning, after you get the ethernet wan working put in 3g settings. For now delete 3g WAN setting. For ip since it's your own modem, you can set it as static ip instead of dynamic and give an ip in the range that the modem dishes out. If Asianet works with Google or Open DNS (try on your laptop first with static ip (for eg static ip 192.168.1.10 & gateway 192.168.1.1 if modem ip is 192.168.1.1) and DNS 8.8.8.8 &208.67.220.220
If it doesn't work, reboot router and see. These settings should work provided ip is given in correct range.
Edit: According to this http://deepak.dk/wordpress/?p=250 may be the problem of DHCP lease even when there's no mac lock. If it's public ip that you directly receive on the laptop then you'll need to keep the setting as dynamic ip. Connect cable to router, call and ask them to do a manual dhcp release and issue. Then the router can will receive an ip. If it doesn't reboot and check.
I am bit confused with ip's.
i did ipconfig with LAN connected on my laptop.
here is the oputput.based on this pls suggest wat ips to put where in laptop ethernet or in router.
Connection-specific DNS Suffix . : asianetindia.com
Description . . . . . . . . . . . : Broadcom Netlink (TM) Gigabit Ethernet
Physical Address. . . . . . . . . : 00-1F-16-C2-DD-A2
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::90d7:ec51:b851:3f51%11(Preferred)
IPv4 Address. . . . . . . . . . . : 111.92.25.62(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.224.0
Lease Obtained. . . . . . . . . . : Sunday, May 04, 2014 6:32:48 PM
Lease Expires . . . . . . . . . . : Sunday, May 04, 2014 7:17:48 PM
Default Gateway . . . . . . . . . : fe80::1%11
111.92.0.2
DHCP Server . . . . . . . . . . . : 202.88.241.81
DHCPv6 IAID . . . . . . . . . . . : 234888982
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-9B-81-6F-00-1F-16-C2-CD-A1
DNS Servers . . . . . . . . . . . : fe80::1%11
202.88.238.4
202.88.238.6
NetBIOS over Tcpip. . . . . . . . : Enabled
