Did you try 192.168.1.1/main.html to access Advanced options/Diagnostics etc ?
also can i use beetel firmware on ut300r2u?
I cannot advise you to do Firmware update from a different model ( in this case Beetel220BX) as I have not attempted it myself.
There are other complications like bin xdsl extensions.
I said read "EULA" .You do things at your OWN risk !
People posting in IBF give it in good faith, and later you blame me or others for total failure/loss of internet connection etc , It HURTS.
Best thing is to shout at the "poor" BSNL staff and get the modem replaced !!!!
or ask them to check the line. They have the instruments.
Your Attenuation is high and this also affects d/l speed.
Recommended SNR >10 Attenuation the least the better your d/l speed.
As there are many variables, ( recently I told someone to try TCPIP optimiser from speedguide and he has reported that because he used it his Internet connection is lost !).Distance from Exchange also affects.
Also the OS used it seems as per BSNL . what is yours ?
Para two : UTSTAR/SmartAx modems no firmware available. in the manufacturer's web sites.
@cool_techie_tvm
I saw your post in Forum
Huawei a year back. To be exact on jan 25th 2007 !
