guys lets not confuse.
there are 2 main things
use internet using mobile
use internet using mobile broadband
use internet using mobile:
till now it was 2G ... things changed and 3G started. downloads were restricted. rates were high.
use internet using mobile broadband:
it is advance version of
adsl where you can get 28mbps and above speeds. the rates are low and speeds are high.
Now some users get confused by using those mobile sims into 3G sticks. Hence they find it expensive.
The back end in both cases are same. Even tikona uses the same 3G technology since long time. Now telecom operators got license, they are also rolling out such schemes and giving tikona a tough competition.
The 3G war will intensify now in coming 1 year.
---------- Post added at 04:30 PM ---------- Previous post was at 04:28 PM ----------
how many network bars you get in VMC? anything over 3 and above will give you best speeds.
try experimenting which corner of your house gets max network bars...
