Hi ACT,
Will this
router work?
Netgear 150 Mbps N 150 Wireless Router (WNR-612)
Specs:
GENERAL
Type: Wireless without Modem
Installation Features: Genie CD-less Installation, Push N Connect using Wi-Fi Protected Setup (WPS)
Controls: Wi-Fi On / Off Software Button
In The Box: Router (WNR612), Ethernet Cable, Power Adapter, User Manual and CD
Supported Software Internet Explorer 5.0, Firefox 2.0, Safari 1.4 or Higher
Brand: Netgear
SYSTEM REQUIREMENTS
Operating System
Windows 7, Windows Vista, Windows XP, Windows 2000,
Mac OS, UNIX, Linux
SUPPORTED PROTOCOLS
Standard: IEEE IEEE 802.11b/g/n
NETWORK FEATURES
Frequency: 2.4 GHz
SPEED
Wireless Speed: 150 Mbps
LAN/WAN: 10/100
CONNECTIVITY
Antennae: External
Number of LAN ports: 2
Number of WAN ports: 1
Number of USB Ports: 0
WAN: RJ-45
LAN: RJ-45
Number of Antennae: 1
SECURITY
Encryption: WPA-PSK, WPA2-PSK, WEP
Other Security Features: Denial-of-service (DoS) Attack Prevention
Firewall: NAT (Network Address Translation), SPI (Stateful Packet Inspection)
ADDITIONAL FEATURES
Other Features: Static and Dynamic Routing with TCP / IP, PPPoE, DHCP (Client and Server), Software Wi-Fi Button Conserves Energy, Three Power / Range Settings Reduce Power Upto 75 Percent
SSID Support Multiple SSID Guest Networks
VPN IPsec, L2TP, PPTP
Thanks
