doom_rider
hi guys,i have been using this forum for quite a while...i was using PPPoE but then for faster torrents, switched to bridge..i liked bridge since its easier to automate connect/disconnect and no need to reboot router..also easy to work around link-removed However, theres a peculiar problem am facing in bridge mode...My connection automatically disconnects anytime between 6 to 6:30 am in the morning...and after that even though my scheduled job reconnects, am not able to establish any connections, not browse etc. the dialer connects and disconnects, if done so, each time assigning a new IP which means it is able to connect to MTNL server...however, i cant ping the same server, or any other site...the problem is resolved only when i reboot my PC...disabling/enabling the LAN doesnt help...am forced to believe something happens to the TCP/IP which gets reset on a reboot...but i dont know what and why...this doesnt occur in PPPoE mode...any of you faced something similar? any solution other than restart so i can automate and dont lose 2 hours of download time?any help appreciatedthanks
