weird netflix problem on bsnl fibre
india
bsnl
i have upgraded my desktop pc fully since then i have been having weird netflix video lagging a little stuttering i mean it is not smooth as before my new cpu is i9 10900k old one was i5 2500(worked fine on old pc with same bsnl fibre) i have bsnl fibre plan 300mbps but i have tried on airtel hotspot it works better i can see what should i do
Press ctrl+alt+shift+D when Netflix is playing a video which is lagging. Post the results after a few minutes (keep the stats open and let the video play for a while) as it also tracks dropped frames (if any).
i keep playing with mtu size :0 but previously on 1492 or 1470 mtu netflix did not have problem but i upgraded my full pc since then this problem occuring my new cpu is i9 10900k motherboard msi z490 it has 2 lan ports one 1G and currently used is 2.5g lan port my old i5 2500k had no lag in netflix i ahve now set mtu to 1456(1428+28) it is better now but still not smooth 100% like on i5 2500k cpu
