Weird Problems Surfing/Downloading?
  • Thread starter Thread starter PankajSh@rma
  • Replies Replies 16
  • Views Views 3,070
Do i need to format my computer?
No. try defragment option. surprised you could d/l Anvir Task Manager within 15 minutes and run the program. ( or you had it earlier ?0 There are so many menu items.
Can you use your system normally OFF line ? say pictures viewing etc ?
^^Man i had earlier tried everything,I even tried registry mechanic and ccleanerAlso some antispyware like spybot and spyware doctor and the one mentioned by youI also defragemnted C://,Ran Scandisk and disk cleaning utilities But still no progress,Things gone weird,I have to refresh atleast 8-10 times to open a site,and on the page where there a lots of pics or sumthin have to refresh a loadz of times,Same thing is happening in all the browsersI think formatting is teh last option :redface:
@/members/pankajsh-rma/
Formatting and loading the OS and UPD is fine.
But if the same problem arises again reformat ?
I told u i am noob
Glad to note , you have gained the confidence now.
For example my question
3. Start/My computer C:/ what is the toal disk space and free space ?
You have not even mentioned the total disk space and free space in C :
Anyway try disksweeperfree2 from Free download essential and useful softwares
DiskSweeper FREE 2.0 - Freeware Files.com - Utilities Category
Will clear some more junk files from your C:/Windows
Select also 0 byte files /exclude system/hidden files.
Even, if now the system fails/crashes, you have decided to format anyway !
No clue/info to the other person to try to locate the fault.
Start/RUN type sfc /scannow ( note space after sfc )
Keep the XP OS CD ready to insert to CD drive.
As effective as formatting.
Still no improvement, Go ahead .
Format the disk and wish you all success.
Hey man my total disk space is 20 GB and free space is 9GB,Forgot to mention it,I might be bit sleepy at the time lols :P
Now i am not even able to download anything using IDM,Whenever i try downloading sumthin IDM this error occurs :(,
http://img150.imageshack.us/img150/7884/20872405yo5.png
Though i can download with firefox after refreshing 8-10 times
Also dude I am downloading softwares reffered by you,I don't know if they wud help The problem might be somethng Else Please see the image,Hopefully u can sort it out :redface:
Also dude i don't know how to set up a bridge connection so i will sever problems after re-formatting
Can u refer me to a noob guide please
Btw thanx for all the help so far :redface:
mine is 40 GB
Windows itself will take minimum 3 to 4 GHz. wait let me check up. mine is 3.68 GB ( Updates uninstall deleted about 500 to 600 MB)
How this is partitioned ? IN ONE hard disk
as C: allotted 9.75 GB free 2.70 GB OS XP Pro SP2 +minimum programs/folders.
....D: allotted 9.75 GB free 2.75 GB backups .
....E :allotted 17.7 GB free 8.12 GB installation files/applications./ ( forget the available GB total another subject )
I have deleted all old System Restore files . Only yesterday's available.
Start/My Computer/ C: Properties/Disk cleanup/ More options/ Delete System Restore files
May be some sort of maintenance work going on. i had also faced problems yesterday when i was unable to connect to the net.earlier there were frequent disconnections.Today i am able to connect .but i am seeing some erratic speeds in my torrents . before i got constant speeds in the range of 25-30 .now there are frequent stallations and speed most of the time remains in 10-15 or below and most of them time below 10 .I am using Ktorrent on Ubuntu 7.10 with DHT off , protocol encryption enabled.
mine is 40 GB
Man i tried one and everything and nothing happened then atlast had to format my computer,Now everything is working fine
Heartily thankinh you for all the help and support,Eitherways i learnt a lots of stuff from you :):yahoo:
