Dish tv had first introduce multi-connection with a monthly rental of Rs 100/ per month with parent connection with maxi package.then they increase rental to Rs 125/- after wards they increase it to Rs 150/- then started new scheme as Child pack .Now they have increase it to Rs.155/- in which they have removed most of the star tv network channels ,zoom,sports channel and others.Now suppose i want all these channels i will have to pay more than Platinum Pack.My question is whats the use of Multi-tv connection?.If my family members want to view any channel suppose say star plus i will tell my family members you go in hall or vice versa OR suppose even i want star plus channel in my child pack i have to pay Rs 50/- which doesn't makes sense.Whether they are following TRAI guide lines or not i am not surebecause previously child connection was on rental basis now it is separate pack. Multi-connection should be in such a way that i should not pay the same amount to view the all channels on both connection.means i should not pay 312 +312=Rs.624/ to view all channels or using add-on packs it should not cross more than platinum pack.Since they have taken same amount for the set-top boxes and given only one dish antenna. Dish tv officials how are the schemes u r implementing which doesn't makes any sense.Take proper Decisions and implement proper scheme so that customers who r connected from long with u will remain with u forever.
