That's totally Strange, but still few things to consider:
Your last test is performed at 3AM and yes, you are in Grace, but what if Speed increase has nothing to do with the fact you are in Grace, but has increased just because you are testing in a period with very low overall Network usage? Have you tested before at such Off Peak hours?
I will encourage you to Keep your Grace until tomorrow and keep on testing during different times of the day. Most important is to test during peak network usage 9PM to 12:30AM
Of course keep all other conditions same if possible. Same Device, same router, same distance from router.
Let's see what tests will show. For me the problem can be only related to some network bottleneck which of course is related to the Time window of usage/tests so let's explore that....
Recently I've noticed that Excitel has started capping torrent speeds at 1MBps, Enyone else noticed or experiencing the same?
This is in East Delhi Region with the 50mbps plan
Tbh the speeds were never so good on non-locally seeded torrents. @Sushubh your Ubuntu torrent is being locally seeded those 10.240.252.x IPs indicate so.
It seems that it is not a case of torrent throttling but I'm getting overall connection speeds of only 8-9 mbps , I will be issuing a ticket with excitel
