AjayJP said:great that you have tested and found that DSL Link is not dropping. So there is no point of changing all the cables and wires. all are good enough.
Yes, I am very sure the DSL link on the modem doesn't flash when there is a disconnection.
Its more of a packet loss thats happening. Normally due to MTU this could happen for Yahoo Messenger and al. The yahoo messenger would get disconnected and connect back as its happening for various chat rooms.
Oh, I see. Well, actually I called up 121 once again this afternoon and I told about the disconnections, the customer care executive told me to go
http://59.144.47.27/ > then go to MTU Tools > then CMTU Tool > then download this tool > then load the CMTU Tool > then change the MTU value to 1454 in CMTU Tool Dialog box. [note : the MTU value before it was changed was lower, don't remember how much it was it was in the 1200's or 1300's]
Well, I forgot to mention one thing to you, yahoo messenger has stopped disconnecting since 2-3 days, as far as i have observed. especially after the engineer changed some port at the exchange 2 days back. but there are disconnections in some chat rooms which i visit regularly.
With the model number of your modem I dont think there is an option to set mtu on the modem itself. With the model number of your modem I dont think there is an option to set mtu on the modem itself.
yes you are right, i tried searching for MTU option, and couldn't find it.
I think the MTU value has been changed to 1454, is this the same MTU value are you talking about?.You would need to change the same on your computer.
Again now to identify if there is a packet loss on the network or is it due to just mtu issue you can probably run a continuous ping.
on command prompt - run a continous ping to some site like google or so.
ping google.com -t
as soon as I read this I did a ping google.com -t on command prompt and noticed 4-5 'Request timed out' messages in between the replies withing first few minutes.
I also did a ping on other two chat sites ( didn't open the chat sites while pinging) in which I used to get disconnected, the same 'Request timed out' messages appeared in between replies to the ping within first few mins.
Just check if there is a packet loss during the time when you loose the connection to MEssenger and chat rooms.
So I should check the replies to ping only when I loose the connection to a particular chat room? what if there is packet loss ( does 'Request timed out' mean packet loss? ) at other times.
How to Optmize your MTU ?
https://www.dslreports.com/front/DRTCP021.exe
Download the tool from the above link. First set the MTU on your adapters to 1500.
Now try ping a wesbite with packet size of 1500-28
ie.
ping google.com -l 1478 -f
if you are getting a reply then the mtu is ok, else if its says packet needs to be fragmented then you need to reduce the value of 1478 to lower. Keep lowering in and find the optimum value. SO if you get a reply at 1460 and at 1461 it says packet needs to be fragmented then your MTU size should be 1460+28=1488 and this needs to be set for your adapters.
You can even find how to optimize the MTU if you search through in google.
I am a bit confused now, the current value entered under MTU value in CMTU tool is 1454. so what do i do now? go ahead with downloading the tool from the website you have given and change the values?
But atleast now you can ask AIRTEL to stop working on cables and splitters. Its clearly nothing wrong with it. Even a modem change may resolve the issue. The reason the modem may not be auto negotiating the MTU.
well, 2 days back the local tech had called and informed that net would be down for 30 minutes, upon asking why? He said he is changing some port at the exchange. after this no lines or cables have been changed. also this morning i made a request for a change of modem and splitter, and I was told it would be arranged.
Also do let me know if you are finding it confusing. I will explain you.
well. not much confusing, you have explained it well, though i am yet to do the googling part and understand how to optimise MTU.
thank you very much for explaining in detail and step-by-step. .
screenshot :
Hey AjayJp. I actually followed the steps you mentioned to find out the optimum MTU and also followed the guide at How do I optimize my MTU and RWIN settings? DSL FAQ - dslreports.com. and to my surprise, the optimum MTU turned out to be 1454, the same MTU number which the customer care executive had told me to enter in the MTU values! lol.
by the way, there are 2 computers connected to the router, one - laptop and two - desktop. I have changed MTU value in both.
ping google.com -t
what error would it show if there is a packet loss?
