Hi, I recently decided to get a static IP from Airtel as I was under CG-NAT. Once they had configured it, I was no longer under CG-NAT, but the IP kept changing for me whenever there was a restart. Not sure why this is the case. I reported it back to the assigned engineer, but no updates from him so far. (Apparently, they email the NOC team to get things done). Has anyone experienced this before?
Moreover, I also asked them to enable bridge mode. They enabled it on Port 4, to which I could connect my Pi flashed with OpenWrt. I added the PPPoE settings and got a public WAN IP on OpenWrt as well. This IP differs from the one I have on my Airtel router. I'm unsure if this is how the bridge should work. There should ideally be a single public IP?
As a side-effect, I noticed my upload speeds dropped to nearly 0. I also tried it without the OpenWrt router, but I still got the same speeds. Downloads are fine; just the uploads are affected. Now I wonder if I should roll back to the previous setup :/
Edit: It seems like my pings have also increased (with and without the secondary router). And there's a very clear degradation in the overall network quality. This is even more visible with the OpenWrt router.
