Airtel V-Fiber (VDSL) - Link Drop & Other Issues [HELP]
  • Replies Replies 381
  • Views Views 155,653
Is it only me or the latency to European servers are fucked up. Getting piss poor download speeds and the latency's been over ~300 ms for the past one week. CS, as usual, had no clue.
1. Tried on every device minimum ping is 50ms
2 Tried on at least 15 different servers same result minimum ping is 50ms
3. i disabled wifi then tried same results
Your 3rd step doesn't clear out the upload issue.
Secondly, If it's the ping's issue. You can't certainly do anything with it.
I used to get less than 20 MS ping 2 years back but then it is increased and now it's 30 ms.
